jerich0
Apr 15, 2020Aspirant
ORBI RBK50 ethernet backhaul is not working - help
I have an existing RBK50 setup with 2 RBS50 satellites connecting via wireless to the RBR50, this setup is working great, but because of working from home, i've had to set up a home office in the bas...
Apr 17, 2020Guru - Experienced User
This is something that FW or reverting back will not fix as this will be a switch issue, not a FW issue. This will happen on any version of FW. My RBK50 satellite is working via ethernet connection behind 4 non manged HP ProCurve 1400/1800 daisy chained swtiches. v2.5.1.8 loaded since it first came out.
After swapping the switch out. What did the status say on the RBRs web page?
What is the mfr and model # of the unmanaged switch you swapped in?
You might do this after you changed the switch out. Factory reset the RBS. First wirelessly connect the RBS to the RBR. Make sure the status appears on the RBR correctly. I would do this with the RBS in the same room as the RBR. Once done wirelessly. Connect the RBS via ethernet and let it auto re-sync. Check the status after about 5 minutes on the RBR. Should change to wired.
Green ethernet features seen on managed or non manged switchs can be another factor.
Historical posts regarding managed and green ethernet switches
Retired_Member
Apr 17, 2020This is something that FW or reverting back will not fix as this will be a switch issue, not a FW issue. This will happen on any version of FW
NOT TRUE...... v2.5.1.8 is not ready for prime time
