jerich0
Apr 15, 2020Aspirant
ORBI RBK50 ethernet backhaul is not working - help
I have an existing RBK50 setup with 2 RBS50 satellites connecting via wireless to the RBR50, this setup is working great, but because of working from home, i've had to set up a home office in the bas...
OrbiBenR
Jul 14, 2020Tutor
I have the GS908 as well. I had to disable the loop back monitoring to get it to work.
Jul 14, 2020Guru - Experienced User
Thanks for letting us know. I'll keep loop back monitoring in mind as well. IGMP and green ethernet should also be disabled if possible.
Enjoy. :smileywink:
