jerich0
Apr 15, 2020Aspirant
ORBI RBK50 ethernet backhaul is not working - help
I have an existing RBK50 setup with 2 RBS50 satellites connecting via wireless to the RBR50, this setup is working great, but because of working from home, i've had to set up a home office in the bas...
Jul 15, 2020Guru - Experienced User
Is IGMP and any green ethernet features on the switch disabled as well?
Best way to connect RBS is to wirelessly connect them first to the RBR. Once they are connected, then connect the ethernet cable between the RBR and RBS while the RBS is still ON. Then the connection will change over by itself if the connection thru the switch isn't inhibiting. You may want to try a different switch if you can't get the status to show a wired connection to the RBS.
OrbiBenR
Jul 15, 2020Tutor
Correct. IGMP and all green settings also disabled. As is monitoring.
