Bawa
Nov 07, 2017Tutor
Orbi RBK50 firmware 2.0.0.74 drops wireless connection and cannot communicate with RBS50 now
I´ve just bought Orbi to resolve wireless dead spot areas in our house. After running through setup wizard, I upgraded router and satellite with latest firmware (2.0.0.74) and now my wireless connect...
- Nov 07, 2017
Sorry st_shaw, nearby wireless devices isn't the problem.
However....... FINALLY some good NEWS, I've reverted back to a stable version of the Orbi RBK50 firmware, V1.11.0.20. This firmware was orginally applied on my devices before I upgraded to latest firmware, 2.0.0.74, and then my wireless network went crazy unstable.
First I downgraded my Orbi router to v1.12.x without any luck, and then I tried downgraded to firmware V1.11.0.20. This did the trick and I have now stable wireless connection and can surf without loosing wireless connection every 30sec.
A bit glad to have a stable wireless network and that my spent $400 was not thrown out of the window. Long way to go to the BestBUY.....
I hope Netgear can test its firmware v2.0.0.74 thoroughly and they will release an updated version of this firmware. I would like to take advantages of these new functions they have added.
Psssttt: don't upgrade to firmware version 2.0.0.74 unless you know what you are doing!
Bawa
Nov 07, 2017Tutor
Hi again!
Done some more troubleshooting today.
Still struggling with unstable wireless network. As written in initial post, I've reverted back to firmware v1.12.x even tough the Orbi RBR50 is not stablizing my wireless net.
This have only to do with the wireless net since I'm not having any problem with wired network through RBR50.
And my satellite device is also struggling....... it shows blue light few seconds and then it turn into magenta color.
While connected to wireless, I've started Pinging the device and I think after 30seconds or less it drops connection and then reconnect after 2-4 missing ping .
