Tommy3012
Jan 07, 2020Aspirant
Orbi RBK50 Firmware upgrade problem
got a handmedown rbk50 , firmware was 1.3.0.26 Both router and Sattelite. Firmware upgrade sattelite is ok to 2.5.1.8 but router won't do anything . when i add the .img en press uplode the weel ke...
- Jan 08, 2020
(It just ruins the whole day when a problem does not get solved. Damn.)
My "absolute last resort" is to tftp the image. Netgear's routers are built with tftp (the most primitive file transfer program ever created). Netgear publishes instructions for Windows here: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
I have uploaded firmware to an Orbi using tftp. (It was either that or box it up and send it back to Amazon, and I had only one day left on vacation to get it working before I left the state to come home.) Surprised hell out of me when it worked.
My Google search seems to indicate that Mac's come with tftp, but I know almost nothing about Apple products.
Tommy3012
Thanks for all the help you already gave , last try was wired and with safari and chrome . nothing changed .
Tommy3012
Setup is IMacto RBR50 wired . do i put the modem in the Orbi or beter not ?
the msg that chrome gets whenthe update fails is : ( in dutch :orbilogin.net heeft geen gegevens verzonden.) so Orbilogi.net did not send any information
- CrimpOnJan 08, 2020Guru - Experienced User
- Tommy3012Jan 08, 2020Aspirant
wil try this later on :
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
don't knowhow to put it but it works!thanks guys for all the help
