miau101
Oct 06, 2018Tutor
Orbi RBK50 firmware V2.2.1.210 update slows WAN speed with 30 to 40%
Firmware V2.2.1.210 slows down my internet speed with 30 to 40%. After bringing it back to V2.1.4.16 the speed is back to normal. No upgrade here!
Oct 06, 2018Guru - Experienced User
Did you factory reset the router and satellites after installing the FW upate? Others mention doing this has helped them.
- miau101Oct 06, 2018TutorHi Furry,
No I did not do a factory reset. At least 15 devices has to setup their wifi settings again. And the complaining of my children and wife is not something I am waiting for. And on the other hand why should I upgrade? Its okay so. Only when I buy the outdoor sattelite, in which I am interested, will change the situation.
For now I am not doing a factory reset but thanks for hand out this solution.- FURRYe38Oct 06, 2018Guru - Experienced User
Keep that in mind for the next FW update. Others say it's helped them. Good Luck.
- miau101Oct 12, 2018Tutor
Can't believe this happening. The router updates automatically. What's the point of revering to an older version? As far as I can see its not something that can be override.
And above of al, I did reset the router and set it up again..the speed is still worse! All the work for nothing.
