miau101
Oct 06, 2018Tutor
Orbi RBK50 firmware V2.2.1.210 update slows WAN speed with 30 to 40%
Firmware V2.2.1.210 slows down my internet speed with 30 to 40%. After bringing it back to V2.1.4.16 the speed is back to normal. No upgrade here!
Oct 06, 2018Guru - Experienced User
Keep that in mind for the next FW update. Others say it's helped them. Good Luck.
miau101
Oct 12, 2018Tutor
Can't believe this happening. The router updates automatically. What's the point of revering to an older version? As far as I can see its not something that can be override.
And above of al, I did reset the router and set it up again..the speed is still worse! All the work for nothing.
