ElJefeReal
Aug 17, 2018Aspirant
Orbi RBK50 Intermittently loses internet after firmware update
Hello everyone - just updated to Router Firmware Version V2.1.4.16 and now have issues with internet dropping intermittently throughout the day. Never had this issue before. Have two satellites. Seems WiFi related since TV is connected via Ethernet cable. When I use Orbi app on iPhone it will say offline and then online then offline all within 5 minutes. Any ideas? Thanks!
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).I would do a full power OFF of the router and satellites for 1 minute, then turn on the router then satellies...
- ElJefeRealAspirant
I can do the power off and back on, but I've had this set up for some time and did not have any issues until this update. It's not the modem, internet service, house size, etc. Everything was fine until this update. Channel is on Auto for 2.4, but was on a solid channel for 5.
