creed0330
Oct 30, 2020Tutor
Orbi RBK50 IPOE?
My ISP protocol by default is IPOE, does anyone know how to config the orbi for IPOE operations? I cant usee PPOE, I have tried, and as mentioned, IPOE is my protocol. Any help would be much apprec...
creed0330
Oct 31, 2020Tutor
ISP is centurylink, fiber, and no, no login creds required.
CrimpOn
Oct 31, 2020Guru - Experienced User
Lots of people have mentioned Centurylink fiber. What happens when you go through the setup and just answer
"Does your internet require a login" - No.
Internet IP address
"Get Dynamically from ISP"
- creed0330Oct 31, 2020Tutor
I'll have to check, but by default, orbi "does ISP require login" is disabled by default, I'd have to check for the other...My ISP said I cant use PPOE, I would have to use IPOE or DHCP... By default, my protocol is IPOE. Just trying to figure out how to config orbi for IPOE.
- CrimpOnOct 31, 2020Guru - Experienced User
creed0330 wrote:I'll have to check, but by default, orbi "does ISP require login" is disabled by default, I'd have to check for the other...My ISP said I cant use PPOE, I would have to use IPOE or DHCP... By default, my protocol is IPOE. Just trying to figure out how to config orbi for IPOE.
If the ISP said use DHCP, I would use DHCP. That is the Orbi default. What happened when you tried it?
Notice the second commend, specifically about CenturyLink fiber:
