the-reader
Aug 08, 2019Aspirant
Orbi RBK50 issues with Qnap connected to Satellite
I posted this yesterday and got confirmation from Netgear it was posted but it seems it was deleted or removed as I cannot find it on my account or in the list of posts. My issue is have a Qnap N...
CrimpOn
Aug 12, 2019Guru - Experienced User
Your description seems clear. There are moderators on the forums who can escalate issues.
- ChLaAug 17, 2019Aspirant
Hi, I have an QNAP TS-509 that I'm trying to connect to my newly purchased Orbi AC3000 router (Firmware: v2.3.5.30). I experince the same issue - I can ping the Qnap, but I do not get any response on any requests. Trying to map drive on PC Win 10, DLNA services or Web-login is all not possible. I have tried to connect the NAS both to the main router and also the satellite - both without luck (ethernet cable).
Have anyone found a solution for this...?
- the-readerAug 17, 2019Aspirant
Not quite the same issue! I can see and connect to the NAS just fine. It's the performance that is affected when connected to a satellite router, the issue goes away when connected to the main router. This is a new issue, was working for 6 months with no issues before
