Akolite
Nov 03, 2017Tutor
Orbi RBK50 keeps rebooting!
Hi there, Just got my shiny new ORBI RBK50 system and after working well for 2 days, The system keeps rebooting every few hours. The satellite stays on and reconnected to the main unit once it is...
Akolite
Nov 03, 2017Tutor
Already done the factory reset and got the RMA for a new unit. One thing I have noticed after running a constant ping to the router for the past day... it reboots every 6 hours, give or take 30 seconds... sounds like that could be a firmware issue?
Streak2
Nov 03, 2017Master
Mine would not reboot but lose connectivity to my AT&T gateway from time to time.
The replacement has been perfect.
- AkoliteNov 06, 2017Tutor
So an update... It has been stable for 3 days... now it is rebooting evey 4 to 6 hours again. I think I am going to send it back to get a new one since it is less than a week old.
- Retired_MemberNov 06, 2017
Akolite wrote:So an update... It has been stable for 3 days... now it is rebooting evey 4 to 6 hours again. I think I am going to send it back to get a new one since it is less than a week old.
This has kind of been the story since 1.10.x.
Since 2.0.x came out, my Orbi was rock solid stable for WEEKS. After a reboot yesterday, the whole system went back to disconnects etc...
No new devices, no configuration changes, no movement in the sats or router, just a reboot and poof, stability is gone.
- gloryguyDec 11, 2017Tutor
Im having the same issue. Tried all the fixes, new firmware, swapping power supplies, factory rest. Today i returned it to Bestbuy and got a brand new one, went through the whole setup and same problem. Sometimes it will run for 30 munites and sometimes a few hours and then reboots. Did anyone ever figure this out. it has to be a hardware issue as i have had several different versions of firmware that all do the same thing. I had a Nighthawk for years that worked fine? Should i try and rma this for a unit from Netgear and not from Bestbuy. The local store told me that everyone has been returning the AC3000 units?
