Akolite
Nov 03, 2017Tutor
Orbi RBK50 keeps rebooting!
Hi there, Just got my shiny new ORBI RBK50 system and after working well for 2 days, The system keeps rebooting every few hours. The satellite stays on and reconnected to the main unit once it is...
eswiderski
Dec 11, 2017Guide
If you're using the latest firmware, this is the issue. Read the other posts regarding the lasted release. Complete disaster.
spinkick
Dec 11, 2017Apprentice
nope, rolled back to 2.0.76, same issue. Stable after the initial factory reset, then, once it reboots itself (memory leak?) it **bleep**s the bed and runs really slow no matter how many reboots you do. Pathetic.
- gloryguyDec 12, 2017Tutor
i have tried 3 of the current firmware versions, all with the same result. The router keeps rebooting. Both units were at 2.0.74 when I got them from Bestbuy. This is why I upgraded them booth to V2.1.1.12 and they still reboot randomly.
- DarrenMDec 13, 2017Sr. NETGEAR Moderator
If your hardware is rebooting I suggest contacting support they will be able to troubleshoot the issue and RMA the unit if needed.
http://www.netgear.com/support/contact.aspx
DarrenM
- aazDec 13, 2017Virtuoso
I've found that UPNP setting being on did what seemed like a reboot of the router when one of the devices on the network kept sending out bad UPNP settings. The Orbi does not handle clearing UPNP settings well it seems. Turning off UPNP made it stable - no more random disconnects.
- gloryguyDec 16, 2017Tutor
aaz wrote:I've found that UPNP setting being on did what seemed like a reboot of the router when one of the devices on the network kept sending out bad UPNP settings. The Orbi does not handle clearing UPNP settings well it seems. Turning off UPNP made it stable - no more random disconnects.
I was also wondering about UPNP, everythme my router rebooted, I would see UPNP messages in the logs for devices that did not require UPNP. I also turned off UNPN and since doing this the router has not rebooted a single time. The router has been running for 3 days now with no issues and no reboots. Im going to skip the RMA for now because I think AAZ may have found the issue.
