Akolite
Nov 03, 2017Tutor
Orbi RBK50 keeps rebooting!
Hi there, Just got my shiny new ORBI RBK50 system and after working well for 2 days, The system keeps rebooting every few hours. The satellite stays on and reconnected to the main unit once it is...
xlerate
Dec 24, 2017Guide
There is a 2.1.1.16 firmware available NETGEAR Support RBR50 / RBS50 Firmware Version 2.1.1.16
Has anyone that installed this able to report if this addresses the issue?
Bug Fixes:
- Fixes the issue where connected devices do not display on the Attached Devices page.
- Fixes the issue where connected devices on the Attached Devices page do not displays the correct Orbi that they’re connected to.
- Fixes the issue where the CPU usage is high when the Orbi in AP mode.
- Hydro130Dec 24, 2017Luminary
xlerate wrote:There is a 2.1.1.16 firmware available NETGEAR Support RBR50 / RBS50 Firmware Version 2.1.1.16
I installed it the day it was released, and it's been working great for me. However, I've never had any issues with random reboots in the past either.
- eswiderskiDec 24, 2017Guide
I've been on .16 for a few days without any reboots/weirdness. On thing to keep in mind: the grass is not always greener. I have a 4500 sq ft house with over 100 nodes...have been through Google Wifi and Velop. Orbis is best so far, even with glitches.
- spinkickDec 24, 2017ApprenticeI suspect many of the issues are client related. One way to try is to shut down groups of devices from connecting and slowly add more in, see if you can narrow it down. An example of this is that pixel 2 devices and Android 8.x devices are being reported rebooting routers. Mine was an issue as well
