Revenant-Knyght
Jan 29, 2020Aspirant
ORBI RBK50 Lag Spikes While Gaming
I installed an ORBI RBK50 system last night. It has one extension. I'm getting terrible lag spikes while playing games, to the point it's unplayable. This seems to be happening on computers that ...
Jan 29, 2020Guru - Experienced User
Wired is preferred for gaming. Does this happend if wire connected?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
You can turn down the power on the 2.4Ghz radio top help get devices to prefer the 5Ghz radio. Under Advanced Tab/Advanced Settings/Wireless Settings
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
The SB6190 had a vulnerability a while ago. Not sure if it was fully fixed. Modem model is not recommended.
Revenant-Knyght
Jan 31, 2020Aspirant
Thank you for the assistance. I appreciate the detailed response. I went through the steps you mentioned without resolving the issue. Further research indicates I'm not the only person who has had this problem. I tested two other routers/extenders from two other manufactures that did not have this issue. This issue appears unique to the Orbi system itself. As such, I will be returning the system.
- FURRYe38Jan 31, 2020Guru - Experienced User
Something I don't see with mine. Have two xbox consoles running behind a RBK50.
Good Luck.
