Swat1871
Dec 07, 2020Tutor
Orbi RBK50 lastest Firmware
Hi I installed today the orbi system and update the firmare to 2.5.2.4 Modellname Gerätename Bisherige Version Status Router RBR50 XXX V2.5.2.4 Keine neue Firmware Version...
- Dec 07, 2020
Swat1871 wrote:I installed today the orbi system
Modellname Gerätename Bisherige Version Status Router RBR50 XXX V2.5.2.4 Keine neue Firmware Version verfügbar Satellit RBS50 Orbi Satellite-1 V2.5.2.4 Bitte haben Sie etwas Geduld... and no other firmware available
but on the netgear server:
BR50 (Orbi Router) Firmwareversion 2.6.1.40RBS50 (Orbi Satellite) Firmwareversion 2.6.1.40could I used it???
and here I found the
https://kb.netgear.com/000062320/RBR50-RBS50-Firmware-Version-2-7-0-70
Every firmware available for the Orbi RBK50 package is listed here:
https://www.netgear.com/support/product/RBK50.aspx#download (Click on the "+" sign to see previous versions.)
Any of these versions can be manually loaded on the Orbi router and satellite.
No one seems to know why some versions say "for U.S. Region Only". It may have something to do with licensing the Netgear Parental Controls software. It may have do to with....(alien spaceships - probably not.) No one knows. Very frustrating.
While you are certainly able to load any version of firmware, some of us are reluctant to be "early adopters" until a significant number of posts have appeared in the forum reporting "how well it went" and there are no longer posts saying "this ruined my network and I had to revert to a previous version."
CrimpOn
Dec 07, 2020Guru - Experienced User
Swat1871
Dec 08, 2020Tutor
thanks
How can I deactivate my wlan at night?
