Greg00001
May 27, 2019Star
Orbi RBK50 locks up internal networking
I purchased a Netgear factory renewed RBK50 kit (RBR50 Router) on Amazon in November of 2018. After initial pains of setting it up everything has been working well until the last few months. I will...
sergio_mb
Jul 08, 2019Aspirant
I've been facing the same issues here at home. Started to happen after I installed some WiFi Ip security cameras (7 in total)...Except for the "20/40Mhz coexistance" that was able, every other configuration was set as proposed below by FURRYe38. Will disable "20/40Mhz" feature above and see what happens. Thanks for the support. All the best, Sergio
Jul 08, 2019Guru - Experienced User
Does the system work if you only put say 3 cameras online?
How many other devices do you have online at once alone with these cameras?
What resolution settings are on these cameras? IF there all set for high resolution and you have 7 online all at the same time, maybe bandwidth over load.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
sergio_mb wrote:I've been facing the same issues here at home. Started to happen after I installed some WiFi Ip security cameras (7 in total)...Except for the "20/40Mhz coexistance" that was able, every other configuration was set as proposed below by FURRYe38. Will disable "20/40Mhz" feature above and see what happens. Thanks for the support. All the best, Sergio
