edboy
Jul 04, 2018Aspirant
Orbi rbk50 login issue
I have a new Orbi which is working fine. However I want to change a route setting and the router password and name I set does not seem to be working. I am tryingto log in from Orbilogin.com. Is that ...
DarrenM
Jul 05, 2018Sr. NETGEAR Moderator
you may need to access the site by going to 192.168.1.1 then if you never changed the router login password it should be admin/password
DarrenM
edboy
Jul 05, 2018Aspirant
Thank you for the quick response. I have tried logging in using the IP address but it doesn’t connect.
- FURRYe38Jul 05, 2018Guru - Experienced User
What is the IP address your getting from the Orbi router when connected to it with a PC?
What the Mfr and mode# of the ISP modem that the Orbi is connected too? Built in router here by chance?
