Triumph-man
Feb 09, 2019Aspirant
Orbi RBK50 major headache
Hi All
Im having an absolute nightmare !
Please someone help before I go insane.
Ive set up my orbi at least 3 times now and ive had it working at least once
Using it through a BT smarthub.
Triumph-man
My current set up is...
Internet comes in from the street into my BT Smarthub
My orbi plugs into smarthub
Looking at the replies below..yes, I obviously have a clash between smarthub and orbi, but im not in the least bit technical and I dont understand the terminology to rectify it.
What I also dont understand is why my Tab s3 will no longer let me access the orbilogin
Feb 09, 2019Guru - Experienced User
Your ISP modem already has a built in router and WiFi so adding the Orbi router is causing a double NAT condition which is casuing problems and possible conflict of IP addressing between the ISP modem and Orbi router.
Please review the 3 suggestions I posted about. You may want to contact your ISP and ask for a tech to help you with configuring the modem for option 1 or 2 and if those don't work, You can configure the Orbi router for AP Mode and let your modem be the host router.
- Triumph-manFeb 09, 2019Aspirant
Thanks Furry
Lets suppose I was going to try option 3
How do I go about this and in what order do I cahnge things ?
If I disable the radio on my BT beforehand then surely that will stop everything else working ?
How do I set up orbi as my modem ? AP mode ?
- FURRYe38Feb 09, 2019Guru - Experienced User
Yes you need to disable the WiFI on the modem.
You can set up the same SSID and PW on the Orbi. So when you go to configure the Orbi for AP mode, set this up first, then you can disable the Wifi on the modem lastly. Then turn ON or connect the Orbi up.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Triumph-man wrote:
Thanks Furry
Now that is the bit I dont understand.
If I need to alter the settings in Orbi from a device whcih is connected to the orbi network ?????
How do I connect to the network if I havent set it up yet ?
