jomcc58
Dec 26, 2020Follower
orbi RBK50 not connecting to iPad pro
Ipad pro is not connecting to Orbi RBK 50
Dec 30, 2020Guru - Experienced User
Bubba2020 wrote:Same issue here after upgrading to the latest firmware. Powering off the satellite fixes the issue. Sucks that two year old software is better than current.
Bubba2020
Dec 30, 2020Aspirant
Nah, downgraded to 2.3, all issues cleared up, including latency issues on older devices.
- Artfuldodger73May 22, 2021AspirantI’m on firmware 3.2.18.1. What are the steps that you took to downgrade? My iPhone and iPad can connect to the router, but zero internet. I have to turn off the WiFi on my device and then turn back on. Or I just leave it on my 5G settings.
None of the other Apple devices (MacBooks, homepods, AppleTV, etc) have this specific issue. What a pain for such a great (and expensive) router. I’m considering selling it (return period over) and going to a different mesh system.- FURRYe38May 22, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
None of the other Apple devices (MacBooks, homepods, AppleTV, etc) have this specific issue. What a pain for such a great (and expensive) router. I’m considering selling it (return period over) and going to a different mesh system. - Bubba2020May 25, 2021AspirantI downloaded the old firmware and downgraded via the router web interface.
This did not solve the problem, I ended up having to mothball the satellite.
I agree that it sucks, but is Netgear or Apple the responsible party here? I don’t know.- Artfuldodger73May 27, 2021Aspirant
I tried a solution yesterday, which seems to be working. Let's see how it lasts.
Steps:
- Login to you 192.168.1.1 to access your admin panel
- Click on Advanced tab
- Expand the Advanced sub-menu
- Click on Wireless Settings
- Change the CTS/RTS Threshold Preamble Modes - 2.4Ghz Preamble from Auto to Short and 5Ghz from Auto to Long.
- Apply changes.
Let's see how long this lasts. I haven't had to disable/enable my iDevice wifi since then. Image is attached.
Orbi AX6000 RBK850
Firmware V3.2.18_1.4.14
