Rk1234
Dec 22, 2019Aspirant
Orbi rbk50 not finding internet w optimum
Trying to set up orbi with optimum. Have modem (arris tm1602) not altice one. Says it cant detect internet. Help
Rk1234
Dec 26, 2019Aspirant
Yes first time ever. Modem is just modem (no wifi). Modem works with old router. When I login to orbi it shows no isp being detected 0.0.0.0.
Dec 26, 2019Guru - Experienced User
Be sure to power OFF both ISP modem and RBR for 30 seconds. Power ON the ISP modem first then let it sync, then power ON the RBR. You might walk thru the setup wizard first with a wired PC and web browser and see if the wizard correctly connects the RBR to the ISP modem.
- CrimpOnDec 26, 2019Guru - Experienced User
This is just a crazy idea, but when someone purchases a Orbi, it comes with 90 days of "complimentary" telephone support. When the product is registered on the Netgear web site, there is link to "support". My Orbi was well past 90 days before I had any issues, so I have never had the fun of talking to Netgear support. If you get to, please report how they solved (or did not solve) your issue.
- satis0007Feb 03, 2020Aspirant
Did it work ? I saw in amazon that we need to do firm ware update?
https://www.youtube.com/watch?v=QDdC16Cz8tk
Did that work ? after firm ware update? Keep us posted
- FURRYe38Feb 04, 2020Guru - Experienced User
satis0007 wrote:Did it work ? I saw in amazon that we need to do firm ware update?
