Poh11
Nov 11, 2018Aspirant
Orbi RBK50 password recovery - security questions didn't work for me
Hello,
I need help to recover my admin password. Tried the security questions for which I am quite certain that my answers were accurate -- first school I attended and my youngest brother's ir...
michaelkenward
Nov 11, 2018Guru - Experienced User
A factory reset will get you back to the default settings and password.
There is a bug in some devices in Netgear's implementation of password recovery. You can get locked into a close loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process because you can't answer the questions.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
Poh11
Thanks... will find some time to do a factory reset. Was hoping I won’t need to do that. But looks like that’s the option.
Thanks Sensei!
Thanks Sensei!
- michaelkenwardNov 11, 2018Guru - Experienced User
Did you ever set a new password? Have you tried the defaults?
- Poh11Nov 11, 2018AspirantYes, I tried default - didn’t work - and I am almost certain I did set a password. I have had other netgear routers before Orbi, as well as Arlo installed. Haven’t encountered issues before, and certainly wasn’t aware of the bug that caused the looping of security questions.
Will report once I have set aside time to go via the factory reset mode.
