wh1tehart75
May 16, 2019Aspirant
Orbi RBK50 poor wifi with Virgin Superhub 3.0
I have an Orbi RBK50 with one satellite and Virgin Media 200mbps broadband. I previously had a Virgin Hub 2 running in modem mode and was getting 130-150mbps. I recently switched to a Hub 3 and have ...
wh1tehart75
Hi,
I tried all of the above but none of them made any difference. I did a factory reset. Satellite is about 20 ft from the router. Distribution is not an issue I get the same 50mbps wherever I am in the house.
May 16, 2019Guru - Experienced User
20 feet is too close. Try 30 feet.
Do you get to spec speeds with the RBR while the RBS is turned OFF?
