supaderp
Jun 21, 2017Aspirant
Orbi RBK50 power light flashingred after v1.11.0.8 update
Hi, I tried updating following the instructions from Netgear site : i.e. Update satellite first then router. After updating the satellite, it was ok. However, while updating the router, the power l...
DarrenM
Jun 22, 2017Sr. NETGEAR Moderator
Hello Supaderp
Have you held the reset button for 10 seconds to factory reset the unit? If that does not work the firmware may of went corrupt when updating the unit and I would suggest contacting support.
http://www.netgear.com/support/contact.aspx
DarrenM
