BANJI
May 03, 2020Aspirant
orbi rbk50 problems since firmware upgrade
1. I am new to ORBI 2. I purchased RBK50 Router PLUS Satelitte together in mid April 2020 3. I connected my Orbi into my BTBroadband Router 4. Orbi was working lovely for one week 5. So impre...
May 03, 2020Guru - Experienced User
Do not use the Orbi app to update FW. Others have reported problems usng Orbi App. Preferred method is to use a wired PC and web browser and download FW files for the RBS and RBR. Updating the RBS first then the RBR lastly.
Use NG support page and input the mode number of the RBR or RBK50 kit and RBS50Y to download the FW files for each:
https://www.netgear.com/support/
For modems with built in routers, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
BANJI
Thank you very much
I shall attempt this later today
I think I’m right in saying that I do not use Orbi as a modem but only as a Router
Kindest, Banji in London, UK
- FURRYe38May 04, 2020Guru - Experienced User
Orbi can't be used as a modem since it doesn't have a modem built in.
Your BT modem is your modem however it already has a built in router. Why I included suggestions for configuring it with your Orbi.
BANJI wrote:
Thank you very much
