Browntownnj
Feb 24, 2021Aspirant
Orbi RBK50, RBS50 & RBS40V wifi calling issues
I’ve noticed that my rbs40v constantly drops the Alexa but not it’s wifi when connected to my rbK50 and rbs50. BUT I do have random issues with wifi calling dropping (not always disconnecting but def ...
Browntownnj
Im on the latest 2.7.2.104 but this was happening as well during the last fireware if not the last two. Basically when they dropped the 75% from transmit power, i started really nicticing this issue. The dropping of alexa has been going on fro the last 4 firmware updates and it seems to only fix itself for about a 2-3 week period after a reset, but im getting annoyed at having to reset my orbi every so often. Right now I can fix the disconnect from alexa with a quick power off but that still is ANNOYING.
Feb 24, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- BrowntownnjFeb 24, 2021Aspirant3300 sq ft home.
Router is in one corner of the home, 50 satellite is in the middle of the home and the 40v satellite is in the far opposite corner of the home as the router so they are making a straight line. The router and the 40v are connected via Ethernet and the satellite in the middle of the home is the only one using the wifi backhaul.
I have little to no interference from neighbors. If I do it’s only in one spot of my home and it’s barely there and not an issue. I own a wifi scanner and have checked the frequencies in and around my home. As for setting a channel vs auto, the issue still persists and has no benefit.
I’m quite familiar with all the settings you’ve mentioned and they are all set as is so that’s not the issue and of course if Ive tried both ways and always end up with those enabled.
Everything you suggested has also been tried and is currently set that way with the exception of ipv6. There is no difference with that on or off and I prefer to have it on.
My satellites are placed roughly 27-33 ft apart with walls, doors and furniture between them. When I scanned at 75% I had amazing coverage and very little issues. 100% causes overlap and 50% doesn’t seem to cover in all the places leaving me with dead spots. I don’t have issues with speed, I have issues with wifi calling dropping or switching between satellites slowly creating gaps in the conversation. I have giga fiber and see speeds between 230-368 on wifi and 900+ When on Ethernet. My biggest issue is that I’m stuck using AT&T’s gateway, but I already have that sorted and it’s not the issue as this wasn’t a problem when using the older firmwares.- FURRYe38Feb 24, 2021Guru - Experienced User
Is Daisy chain enabled on the RBR?
Has a factory reset and setup from scratch been performed since last update?
- BrowntownnjFeb 24, 2021AspirantYes Dailey chain has been enabled and yes two factory resets have been done as well as an manual update to ensure all updates were done correctly.
IF 100% is causing too much over lap then move the RBS farther away. They can be moved and place at greater distances. 30 feet is a starting point, however not necessarily a rule that you have to have them right at 30 feet. Others have reported having there RBS out at 60 feet. I have one of mien at 40 feet down in a basement area. I have great coverage and no dead spots.
Seems like all this could be better helped by geting better placement and distances between the RBR and RBS to better get you the best coverage that the RBR and RBS can offer.
- BrowntownnjFeb 24, 2021AspirantI literally have them in each corner of the home. Unless I move them outside there is no further they can be placed. And before you say to remove one of the satellites, I’ve done that and just attempted to use the two 50’s, but that didn’t generate enough coverage and I was losing wifi speeds due to all the walls regardless of the placement.
