Browntownnj
Feb 24, 2021Aspirant
Orbi RBK50, RBS50 & RBS40V wifi calling issues
I’ve noticed that my rbs40v constantly drops the Alexa but not it’s wifi when connected to my rbK50 and rbs50. BUT I do have random issues with wifi calling dropping (not always disconnecting but def ...
Feb 25, 2021Guru - Experienced User
Well take out the RBS40 and run the 50s only. Move them around more and use 100% on the RBR. See if you can get more coverage with the two 50s with better placement and distances.
And turn OFF Daisy Chain on the RBR as well.
- BrowntownnjFeb 25, 2021AspirantDailey chain is off and no, the two 50’s don’t cover the home no matter where I place them.
- FURRYe38Feb 25, 2021Guru - Experienced User
Try rolling back to privious FW that worked for you then.
