Scampy
Jul 06, 2017Tutor
Orbi RBK50 rebooted without warning
I have had the Orbi for just under a week now, and so far I have been very impressed. Everything has worked fine and I've had a stable and fast LAN and Internet access from all my connected devices....
peteytesting
Jul 06, 2017Hero
hi
check the system didnt just auto update the firmware as this will cause it to reboot
Scampy
Jul 06, 2017Tutor
Thanks for the reply.
The firmware level has not changed. It updated last week when I first installed the units. Both the router and its satellite loaded the latest firmware, so I don't think that's the problem.
- peteytestingJul 06, 2017Hero
just keep an eye out for it doing it again , if it continues you might want to get a replacement unit from where you bought it from
- ScampyJul 06, 2017Tutor
That sounds sensible.
Do you know if there is a way of seeing logs from before the reboot? It might have given a clue as to why it crashed.
dont think so as it doesnt have a way to save logs to separate server
