Cpawl
Dec 15, 2019Follower
Orbi rbk50 Router no internet but satelite does??
Got an orbi rbk50 router and one satellite last week, was working fine for a few days but now the router has no internet connection but the satellite has, have tried power cycles and reboots, any help...
Dec 16, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Turn OFF the RBS temporarily while troubleshooting.
Has a factory reset and setup from scratch been performed ON the RBR since last FW update?
