sharok
Apr 04, 2017Tutor
Orbi (RBK50). Router sends 150mbs but the satellite speed test shows 40mbps
I get 150mbs from my Netgear modem (CM700) to my Orbi router speed test using a desktop hard wired to my router. Orbi satellite is downstairs and when I speed test using my wireless laptop I get abou...
- Apr 04, 2017
If you measured 85 Mbps from Ookla you can trust that. You can also try this speed test site: http://www.dslreports.com/speedtest
For testing the speed of your network you should use a tool like iperf3, and test between two computers on your LAN. Internet speed tests can be variable and can lead you to incorrect conclusions.
sharok
Apr 04, 2017Tutor
This is a little odd. I came home to start the test procedure you suggested me. But I wanted to run the speed test again, this time with Ookla (a friend of mine told me to use that site for the test).
With Ookla without moving my laptop, I got 85Mbps, while with Cox Internet speed test I get 48Mbps.
My Internet is with Cox.
Which one should I trust?
Cox or Ookla?
If my speed is 85Mbps as Ookla indicated, I'll be very happy with it.
st_shaw
Apr 04, 2017Master
- sharokApr 04, 2017Tutor
I used the website that you suggested. that one shows me even higher Mbps than Ookla, it says 90Mbps.
