Orbi-11519
Oct 17, 2022Aspirant
Orbi RBK50 Satellite Issues
I have the RBK50 orbi system with one router and one satellite connected wirelessly. Both updated to latest firmware and set up with minimal interference. Router is in the basement and satellite is a...
Orbi-11519
Ahh, makes sense! Do you think that a wired 100Mbps would get more stable performance than the 225Mbps over wifi? I was having buffering issues with the built in netflix app while using the wired from satellite and content not loading to full quality - was dropping down to 720P and below it seemed like at times. I also do have the ability to do a MOCA set up directly to the router but not sure if that is overkill. For additional context, the set up I have is an LG C2 and PS5.
Orbi-11519
I did another test of speeds on the ps5 which has a gigabit ethernet port and it matches performance I was seeing on the TV. Have tried with a couple ethernet cables (all are cat 5E) Speeds below:
Wired from satellite: 50-60 Mbps
Wifi from satellite: ~225Mbps
Wifi from router (satellite disconnected): ~225Mbps
I'm getting ~850-900Mbps down and up at my router.
