wccarithers
Jun 17, 2018Follower
Orbi RBK50 satellite lost sync and troubleshooting guide doesn't restore
My satellite lost the link to the router, The ring led flashes white. I tried the troubleshooting guide of placing the satellite right next to the router, pressing scan on the router and then scan on...
Jun 18, 2018Guru - Experienced User
What FW version is loaded on the RBR and RBS?
RBS needs to be upgraded first then the RBR.
I had to do this yesterday at my friends place with his kit. Kita was on v1.0.something.something. The RBS didn't accept the most current version of FW so I had to upload and intermediate Version 2.0.0.74 on both RBS first then RBR, Then after the RBS was reconnected, then I upgraded to v2.1.4.16 which was detected on the RBR FW update page for both the RBR and RBS. Not a great first initial set up experiece. Thank god for capturing what others have done here in the forums.
What Mfr and model# ISP modem are you using?
Distance between the router and satellite? 30 feet to start.
What channels are you using? Try 1, 6 or 11 on 2.4Ghz.
Disable MIMO, Daisy Chain and Fast Roaming...
Last resort, do a ERASE on the satellites, then router then set up from scratch.
