YKkkk
Feb 06, 2021Aspirant
Orbi RBK50 Satellite
Model: Orbi RBK50 Firmware: Latest OS: Windows Hi everyone, I'm YK from Singapore and i require some urgent assistance from the community over here today! Currently im using Orbi's RBK50 (L...
Feb 06, 2021Guru - Experienced User
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-port-forwarding-doesn-t-work/td-p/1984296/jump-to/first-unread-message
YKkkk wrote:Model: Orbi RBK50
Firmware: Latest
OS: Windows
Hi everyone,
I'm YK from Singapore and i require some urgent assistance from the community over here today! Currently im using Orbi's RBK50 (Living Room) + satellite (Study Room). Today i attempted to connect my company's issued laptop to Orbi's satellite in the study room however the Internet connection keeps dropping despite the laptop reflecting "Connected".
I manage to did some trial-and-error and isolated the issue to the compatiability of the Orbi's satellite with my company's laptop. This is because i manage to connect to the Orbi's Main Router without any issues unlike this connection to satellite issue.
alokeprasad
Feb 06, 2021Mentor
Does your laptop have an ethernet port?
If yes, see if the internet connection is stable when connected to the ethernet port on the satellite.
Are other devices connected to the satellite functioning correctly?
PS: trying to see if the problem is with the wireless backhaul connection between the RBR and RBS or with the WiFi connection of the device to the RBS ...
- vajimFeb 06, 2021Master
How far is the sat from the router?
- YKkkkFeb 06, 2021Aspirant
alokeprasad wrote:Does your laptop have an ethernet port?
Unfortunately my MBP does not have any ethernet port :/ But my 2x iPhone and Macbook Pro was able to connect to the satellite without any issue base on what i see in Netgear Orbi's interface.
