YKkkk
Feb 06, 2021Aspirant
Orbi RBK50 Satellite
Model: Orbi RBK50 Firmware: Latest OS: Windows Hi everyone, I'm YK from Singapore and i require some urgent assistance from the community over here today! Currently im using Orbi's RBK50 (L...
vajim
Feb 06, 2021Master
YKkkk wrote:
vajim wrote:
YKkkk wrote:
vajim wrote:How far is the sat from the router?
The Sat is approx 5 meters away from the router, shouldnt be too far away right?Try it
as long as the sat rim light stays OFF you should be fine
I mean 5 meters is within the recommended range right?
Yes 5 meters = about 16 feet. Should be fine. You can actually go about 9 meters
YKkkk
Hmmm my Sat light is off and i didnt have any issue connecting my iPhone or MBP to the satellite :/ Anyway i have this "GlobalProtect" VPN on my company's laptop, could this be messing up with the satellite and not the router?
- vajimFeb 06, 2021Master
YKkkk wrote:I mean 5 meters is within the recommended range right?
I wouldn't think so
the vpn on the laptop is for the laptop
if it bothers you turn it off when not needed
- YKkkkFeb 06, 2021Aspirant
I wouldn't think so
The problem with this company laptop that was issue to me is that i had to login to this VPN inorder to gain access to the internet and turning off isnt any options as it has been overwrite by the adminstration.
- vajimFeb 07, 2021Master
I wouldn't think so
Don't worry about. Another option would be to shut the laptop off when not in use
