ianklug
Feb 14, 2019Aspirant
Orbi RBK50 seems to be blocking ICMPv6 traffic to Internet Gateway
I have an Orbi RBK50 on FW 2.2.1.210 set up in IP Passthrough mode from an Arris NVG599 RG from AT&T, which is connected to our fiber ONT. We have native IPv6 provided by AT&T.
Whenever I connect m...
ianklug
Thanks for the suggestion! I had it in AP mode with DHCP managed by the gateway for a couple weeks recently to see if it improved things, same problem was occuring then when connected to the Orbi, wired or wireless. Ended up switching back to passthrough mode because it enabled settings that weren't available on the gateway, like setting custom DNS servers. Doesn't seem to matter if the gateway or the orbi is doing the routing, this problem still seems to occur. :/
Feb 14, 2019Guru - Experienced User
You might contact NG support and ask about a beta. Other users were having IPv6 problems and one user said he got a beta which fixed his IPv6 problems. Maybe this might be helpful for you:
