Pamela1226
Oct 24, 2019Aspirant
Orbi RBK50 setup problem
Just got my rbk50, and try to do setup with my modem. Followed the instructions, orbi light turn from white to magetna to blue, but after a few seconds (with enthena cable connect to modem), the ...
- Oct 24, 2019
Make sure your connecting the RBR to the modem and the RBS is place out at a remote location. You don't hae to setup the RBS first. I would first get the RBR setup with the modem. Set up a SSID name that you want. Can be anything. Something custom. Can even use your prior SSID name and use same Password as well if you like.
Once you get the RBR setup well, then go for connecting the RBS.
Oct 24, 2019Guru - Experienced User
- Pamela1226Oct 24, 2019Aspirant
I am using the modem from internet service provider. When I connect orbi to mobem with ethernet cable, the connection is working on orbi. But once I try to un-plug the cable, the light changed back to magenta...i haven't even move the orbi yet.
