Pamela1226
Oct 24, 2019Aspirant
Orbi RBK50 setup problem
Just got my rbk50, and try to do setup with my modem. Followed the instructions, orbi light turn from white to magetna to blue, but after a few seconds (with enthena cable connect to modem), the ...
- Oct 24, 2019
Make sure your connecting the RBR to the modem and the RBS is place out at a remote location. You don't hae to setup the RBS first. I would first get the RBR setup with the modem. Set up a SSID name that you want. Can be anything. Something custom. Can even use your prior SSID name and use same Password as well if you like.
Once you get the RBR setup well, then go for connecting the RBS.
Pamela1226
It was the satellite. The light change from magenta to blue and turn off while connecting with ethernet cable to modem. After un-plug the cable, the light changed to magenta.
The fireware on the orbi should be under the factory setting, as I can't make change on anything now.
Oct 24, 2019Guru - Experienced User
IF you want to connect the RBS to the RBR, it needs to be connected to the RBR, not the cable modem.
The LED process is correct, when the LED turns WHITE, PINK then BLUE then OFF, OFF means the system is working.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Pamela1226 wrote:It was the satellite. The light change from magenta to blue and turn off while connecting with ethernet cable to modem. After un-plug the cable, the light changed to magenta.
