rkarthik_75
Jun 12, 2020Aspirant
Orbi RBK50 shows 404 and 401 error codes but other routers don't - bad experience
Mobile phone, Smart TV, Andriod TV Box and laptop browsers showing 404 and 401 error codes or not loading up while using Orbi router - bad experience. Most websites are not loading after install...
- Jun 25, 2020
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Jun 25, 2020Guru - Experienced User
rkarthik_75
Jul 06, 2020Aspirant
Thanks FURRYe38 for the detailed answer. I only have answers to those I can see in the ORBI app. So only answered those. For the rest I don't see any way I make the changes you have mentioned. I have explained below inline to your questions:
- Hardware version RBR50
- Firmware version - v2.5.1.16AU
- S/N - 5PK2925M00800 (for ORBI)
- Hardware type - Orbi
- Orbi android app version - 2.5.4.1036
- ISP is TPG and the modem & router supplied is Archer VR1600V v1.0.
- Archer VR1600V Firmware - 0.1.0 0.9.1 v5006.0 Build 180828 Rel.56416n
- ORBI is connected to ISP's modem Archer VR1600v. I'm connected to ORBI router and only use apps like OBRI, youtube, facebook etc. is working. Any browser based activity is showing 404 and 401 errors.
- I'm not sure what is meant in the second part of the question - NG router is connected?
- I have no idea where to check this! Please let me know
- Less than 30 feet between satellite and router. Router and Satellite has synched.
- Satellite is showing the in app dashboard after resetting and rebooting the router.
- BTW, the signal strength shown in Orbi app is -35dBm, which seems to be v good as shown in the app. So the signal is not weak from router!
- 2.4 Ghz channel is changed to 6. Both 404 and 401 error codes are shown even when different channels 1, 6 or 11 are used.
- Currently, 5 Ghz it's Auto and 36.
- Yes, 3 neighbours on the side, none at the back. How does this help?
- Can't see Beamforming, MIMO options in the modem browser UI
- WMM was enabled already
- Armor, Circle, Daisy Chain, Fast roaming, IPv6 were disabled and rebooting done. Not helpful even after multiple times rebooting modem and Orbi router.
- Set 20/40Mhz Coexistence to 40Mhz only - Is this also in Channel width currently only 20 Mhz and 40 Mhz are the options in the drop down.
- Set Short preamble instead of Long preamble modes - Can't see this in Advanced settings in Modem or Orbi app. Where can I find this?
Thanks FURRYe38 for trying to solve this but I really miss phone trouble shooting/tech support. Could you give me a call at +61 469 241 444. I'm in Australian EST.
I'm sure many cufstomers like me who don't have premium suppport and only have the community to depend on are going through what I'm seeing for myself during this difficult times.
- FURRYe38Jul 06, 2020Guru - Experienced User
Your ISP Modem has a router built in, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
rkarthik_75 wrote:Thanks FURRYe38 for the detailed answer. I only have answers to those I can see in the ORBI app. So only answered those. For the rest I don't see any way I make the changes you have mentioned. I have explained below inline to your questions:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).- Armor, Circle, Daisy Chain, Fast roaming, IPv6 were disabled and rebooting done. Not helpful even after multiple times rebooting modem and Orbi router.
- rkarthik_75Jul 07, 2020Aspirant
Thanks FURRYe38 --> GURU and LeBob for your assistance and your inputs regarding my issue. The 404 and 401 error codes don't appear anymore and I can even connect to work VPN site and not just browsing websites!
So, I called the tech phone support yesterday (based in Ireland, as India team is not working) and big high five to Alexandro who did a terrific job of troubleshooting with me step by step on the other side.
Just FYI, to all your customers trying to get a tech phone support, to call during Ireland working hours/timezone. I'm based out of Sydney, Australia and the call was not assigned to any tech support staff for 1 hour 10 minutes. Yes! That's my waiting time on the phone.
- FURRYe38Jul 07, 2020Guru - Experienced User
So what resolved this for you?
rkarthik_75 wrote:Thanks FURRYe38 --> GURU and LeBob for your assistance and your inputs regarding my issue. The 404 and 401 error codes don't appear anymore and I can even connect to work VPN site and not just browsing websites!
