rkarthik_75
Jun 13, 2020Aspirant
Orbi RBK50 shows 404 and 401 error codes but other routers don't - bad experience
Mobile phone, Smart TV, Andriod TV Box and laptop browsers showing 404 and 401 error codes or not loading up while using Orbi router - bad experience. Most websites are not loading after install...
- Jun 25, 2020
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
rkarthik_75
Jul 08, 2020Aspirant
Below settings were applied all at once and not separately. either one or a combination of these could've resolved it.
wireless set up - 2.4 ghz was set to channel 6. 5 Ghz was set to channel 36
parental control - smart and standard parental controls were disabled
advanced setup - enabled 20/40 MHz coexistence, enabled daisy-chain topology, enabled implicit BEAMFORMING, enabled MU-MIMO, enabled fast roaming
- kept router mode unchanged
- IPv6 was always disabled
rebooted orbi multiple times after above settings were applied
Jul 08, 2020Guru - Experienced User
Ok. Thanks for letting us know. Be sure to make a backup configuration to file for safe keeping. Saves time if a factory reset is needed.
Enjoy. :smileywink:
