Hasselblad100
Mar 06, 2021Aspirant
Orbi RBK50 Slow WiFi in AP Mode
Hi I have seen a similar post on this but would like to confirm before I return the hardware... I have an RBR50 wired to an ISP Router (Sky in the UK) and 1 RBS50 satellite. The Sky router ca...
Hasselblad100
ok, thanks for the response. So that kind of says that Sky Hub and Orbi don't play well together unless you can live with double NAT. Sky has no modem-only mode and its the same problem for BT
vajim
Mar 06, 2021Master
Hasselblad100 wrote:ok, thanks for the response. So that kind of says that Sky Hub and Orbi don't play well together unless you can live with double NAT. Sky has no modem-only mode and its the same problem for BT
that's too bad
can you use a different brand modem (Non-Sky)?
