Hasselblad100
Mar 06, 2021Aspirant
Orbi RBK50 Slow WiFi in AP Mode
Hi I have seen a similar post on this but would like to confirm before I return the hardware... I have an RBR50 wired to an ISP Router (Sky in the UK) and 1 RBS50 satellite. The Sky router ca...
Hasselblad100
Hi
ISP options are limited where I live, unfortunately no Virgin Media. I can get a 3rd party modem and t try to set that up, Vigor 130 or similar
Mikey94025
Mar 07, 2021Hero
Hasselblad100 wrote:
Hi
Do you have a use-case where Double NAT doesn't work for you? It's not recommended (because there are such use-cases, like some games) but if it works then go for it. I personally run my household and 50+ IoT devices with Double NAT and it's not a problem for me.
It is strange that running in AP mode is problemmatic for you because your wifi speeds shouldn't be different talking to the Orbi. But don't let that problem force you to abandon Orbi if Double NAT works well for you.
- Hasselblad100Mar 08, 2021AspirantI have a music streamer that where UPnP discovery can be problematic with double NAT but all okay so far
