Claudi0
Apr 29, 2020Aspirant
Orbi RBK50 speed locked at 100M
I have a Orbi RBK50 and I am having an issue with getting more than 100M over a cable connected in the sattelite. My ISP speed is 300+ and I am getting that over WAN but if I plug in a ethernet cabl...
Claudi0
May 02, 2020Aspirant
Tried all of the above and it does not change anything.
Just to be clear I am getting 300+M on wifi devices, the issues here is with wired devices connected to the satelite.
May 02, 2020Guru - Experienced User
Do you get 1000Mbps and to spec speeds when connected to the RBR?
Possible the RBS could be faulty.
Claudi0 wrote:Tried all of the above and it does not change anything.
