Tigerdansken
Aug 19, 2020Aspirant
Orbi RBK50 speed only 20% of the line capacity
Hi! I have bought an Orbi Rbk50 because I have some dark spots at my house, but I have some issues regarding speed. I have a 500/500mbit internet connection, and I am close to that speed when I ...
- Aug 19, 2020
No switch, the cables are connected directly to the Zyxel.
I have found the answer... The LAN cables installed inside the wall are Cat5, and therefor limited to 100mbit. I was pretty sure they where Cat5e, but no. I guess its time to call a electrician to change them.
"There's always a logical answer, if you have all the facts!" :-)
Thank you for your help :-)
Mstrbig
Aug 19, 2020Master
What is your ISP? What ISP modem/router do you have. Is your Orbi router connected directly to the ISP modem/router or to a switch, then router?
Tigerdansken
Hi.
I have Telenor (living in Norway) and im using a Zyxel p8702n (modem/router) that Telenor has provided. Orbi is connected directly to the Zyxel.
I have found the answer... The lan cables installed inside the wall are Cat5, and therefor limited to 100mbit. I was pretty sure they where Cat5e, but no. I guess its time to call a electrician to change them.
Thank for your help anyway :-)
/jonas
- MstrbigAug 19, 2020Master
Is there a switch inside the closet that connects to the Zyxel? If so what brand and model? Or do the cables connect directly to the Zyxel?
- TigerdanskenAug 19, 2020Aspirant
Thank you for your help :-)- FURRYe38Aug 19, 2020Guru - Experienced User
I recommend you install CAT6 cabling. :smileywink:
Tigerdansken wrote:No switch, the cables are connected directly to the Zyxel.
Hey I'm glad you were able to figure it out.
