srdavis872
Apr 10, 2020Apprentice
Orbi RBK50 Speeds Drop
I recently bought an RBK50 kit with an RBR50 router and RBS50 satellite. Set up was kind of a pain. It's been working for a while with some disappointing performance. Internet service that I get is a...
Retired_Member
Apr 10, 2020
srdavis872
Do you know how I can install a previous firmware version?
look for the download area here and enter your model number....
here's your bette choice:
RBR50 (Orbi Router) Firmware Version 2.3.5.30
then stop looking and perfomring manual updates....NG will push critical updates with no action required by you
srdavis872
srdavis872
I'll try it out. And I only updated because it was during setup and I think it asked me to. I'll leave it alone otherwise.
