GamerXYZ's avatar
Sep 04, 2017
Orbi RBK50 SSID not in list
I'm trying to set up the Orbi RBK50 system (so, to be clear: it's new and straight out of the box). The first 2 steps in the quick-start guide went without a hitch: I end up with a blue light. But th...
  • st_shaw's avatar
    st_shaw
    Sep 07, 2017
    Well, if you can reach the login screen but cannot log into the router using the default username/password then something is very wrong.  If done properly, the reset will restore the default login credentials.  You must hold down the reset button for a long time until the power LED starts blinking amber for the reset to be effective.
