110dad
Mar 04, 2020Aspirant
Orbi RBK50 streaming issue with Dish Network - Dishanywhere
I just set up a new Orbi RBK50 to replace my old TP link router. The Dishanywhere streaming worked on that router. After I switched over to the Orbi, I can no longer stream from Dishanywhere. I am...
Mar 04, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Last time I checked my DishAnywhere on my pad, it worked fine with my RBK50. Been a while since I don't use it much. Mostly use the Hopper. Streaming Netflix is working. Though it's wired to the Orbi.
