110dad
Mar 04, 2020Aspirant
Orbi RBK50 streaming issue with Dish Network - Dishanywhere
I just set up a new Orbi RBK50 to replace my old TP link router. The Dishanywhere streaming worked on that router. After I switched over to the Orbi, I can no longer stream from Dishanywhere. I am...
theoak
Mar 04, 2020Luminary
I have my Orbi Router connected to my Dish Hopper 3 via network cable (middle network port on the Orbi to the bottom network port on the Hopper) . I just tried DishAnywhere on my local network here at home on my phone - worked great.
My Orbi system is in Access Point mode - not sure what your configuration is.
- FURRYe38Mar 04, 2020Guru - Experienced User
Last time I checked it was in router mode.
Possible that your main host router is blocking something if your trying to access from a remote location. If it works when your on the LAN side then Orbi is only passing thru traffice to the host router. I would look at the host router for possible causes....
Just checking with my phone from here at work to see if the app would launch and log in. It does.
