johnny0206
Sep 02, 2020Follower
Orbi RBK50 Switching AP mode then no internet
I login Orbi admin then misstakenly switch it to AP mode, then the internet is down. And couldn't connect to Orbi wifi and the login web to switch it back. was following this youtube: https://www...
Mstrbig
Sep 02, 2020Master
johnny0206 wrote:I login Orbi admin then misstakenly switch it to AP mode, then the internet is down. And couldn't connect to Orbi wifi and the login web to switch it back.
was following this youtube: https://www.youtube.com/watch?v=H7LOcJ8GdDo&t=3s
How to reset it? thanks
If you switched your Orbi to AP mode before switching your router, you now have no DHCP server.
You can plug into the Orbi router and log in and change it back to router mode.
