johnny0206
Sep 02, 2020Follower
Orbi RBK50 Switching AP mode then no internet
I login Orbi admin then misstakenly switch it to AP mode, then the internet is down. And couldn't connect to Orbi wifi and the login web to switch it back. was following this youtube: https://www...
AmyManch
Nov 01, 2020Aspirant
Did you ever get this solved. I just did the same thing and can't figure out how to change it back.
- FURRYe38Nov 01, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeIf your trying to get to the RBRs web page in AP mode, look at the host routers connected clients list to see if the RBR is listed there, if it is, use the IP address you see there to access the RBRs web page in AP mode.
AmyManch wrote:Did you ever get this solved. I just did the same thing and can't figure out how to change it back.
