s22tran
Sep 18, 2017Aspirant
Orbi RBK50 taking long time to appear on available wireless networks
I just got an Orbi RBK50 and it is taking a really long time for it to appear on my available wireless networks, is this normal? At first I thought the units weren't working because it would take so ...
s22tran
Btw Firmware is 1.12.0.18
- s22tranSep 18, 2017Aspirant
More info.
Not using any antivirus software
Using Linksys WUSB6100M AC600 usb adapter
Windows 10
- DarrenMSep 20, 2017Sr. NETGEAR Moderator
Hello s22tran
I suggest contacting support if there issue with the orbi unit.http://www.netgear.com/support/contact.aspx
DarrenM
