s22tran
Sep 18, 2017Aspirant
Orbi RBK50 taking long time to appear on available wireless networks
I just got an Orbi RBK50 and it is taking a really long time for it to appear on my available wireless networks, is this normal? At first I thought the units weren't working because it would take so ...
s22tran
More info.
Not using any antivirus software
Using Linksys WUSB6100M AC600 usb adapter
Windows 10
DarrenM
Sep 20, 2017Sr. NETGEAR Moderator
Hello s22tran
I suggest contacting support if there issue with the orbi unit.
http://www.netgear.com/support/contact.aspx
DarrenM
